Before I get into this I want to make sure I give Credit to Charles our General Manager for all the hard work he has put into this car..
I am starting this thread to share the changes we are making to the Nitrous Outlet shop car.
To recap the past.
Long story short the car is a Hugger Orange Z28 on a set of 275 drag radials.
The car was painted Hugger Orange by Sykora Truck.
Aluminum block LS2 402 engine, Texas Speed Texas giant cam shaft, Trick Flow 235 Heads from Brian Tooley, Super Victor intake with Accufab 4150 throttle body. Installed in the car by Sunshine Performance in Killeen, TX.
Transmission is a Stock case power glide with 1.80 First gear.
9 inch rear end with 390 gears.
Suspension consist of PA Racing A arms, PA Racing K member, Mad Man Torque Arm, Mad Man Travel limiters, Wolf Rear sway bar, Strange double adjustable front shocks, Strange single adjustable shocks on the rear and race brakes all the way around.
The Nitrous system consist of A Nitrous Outlet spray bar being feed by a .125 Nitrous solenoid and a .187 Fuel solenoid. Dual 10 lb bottles in our nice billet bottle bracket.
Stock PCM Using the EFI Live Custom Operating system, set up and programmed by lorenze at LSX Tuning.
Lingenfelter two step.
The car started off as a T-top car that we converted to a hard top.
Before.
Took the roof skin off.
Weight reduction.
The donor car.
We removed the roof skin and framing that goes across the top of the door jam.
Just a little more fun.
The new roof skin painted by J&M Collision.
To recap the past.
Before.
Weight reduction.
The donor car.
