Originally posted by BttleFedC10
No bass when Switched to CD or AUX on head unit.
Now that i think about it. I got up under the dash and just saw the blue wire and tepped it in. Its kinda cramped up under the dash and yeah. lol. Shit man, ill take a look at it when i go on lunch. Its probbaly what i did. lolOriginally posted by jluv View PostAre you sure you used the remote wire lead off the head unit and not the power antenna wire like they are suggesting above? Typically remote leads are solid blue and the antenna lead will be blue with a white stripe. (Double check that, as it has been a minute since I hooked one up this way. I usually run my switched power from elsewhere and use a relay because I have a ton of different amps and accessories that I need to come on.) Constant 12v is usually yellow on the back of your head unit.
When in doubt, you can tap into another switched lead somewhere else on your vehicle and just run that to your amp so that it comes on with your ignition.
You answer lies in this previous post.Originally posted by Reefer Rae View PostWhen it goes to aux the antenna powers down and that is what u used as a power for your amp .
Just so you know, on most name brand decks...
Solid Blue wire = Power Antenna
Blue wire with white down the center = Remote wire for amp
*EDIT* - guess others already answered, so go fix it already!
