Is it possible to turn a garage that has 2 doors into just 1 door? Theres 2 doors and seemingly a decorative divider in between the doors.
Garage Door Question
kick ass. i can barely squeeze the wife's edge in the garage. do I contact a garage dude or general contractor or what?Originally posted by Lason View PostYeah, my neighbor had it done and I plan to soon. Alot depends on how the house was built though, you may have to install a new header spanning the whole way above the new single door.
Hire a garage door dude. There is some fine tuning involved for a smooth running setup. I know someone in Terrell. He adjusted mine after I installed it and it is much smoother.Originally posted by gonzo View Postkick ass. i can barely squeeze the wife's edge in the garage. do I contact a garage dude or general contractor or what?
That is the best thing. Have it framed by a general contractor, and have me install the new garage door.Originally posted by bard View PostYou'll want a general contractor for the removal of the most likely supporting middle beam and a garage door person to change over to a single door. Is there brick over the door way or wood?
Doors Done Rite
i did that to my house when i first bought it. it had been enclosed, and i wanted a garage back, but found out that it used to have 2 doors with a center post. the two 2x12's couldn't support the weight over a 16' span, so i found a lumber yard to do the calcs and ended up getting a 14 LVL that i lag bolted and nailed to the existing 2x12's, and used 2x6 framing above and below so the load was sitting on all 3 beams. then had a single door put in and it's been 3 yrs with no problems. a pain in the ass, but it worked.
you'll want to check with the city about permits and stuff, too. mine was a simple one story so that made it easier, but i'd definitely do your homework before you go tearing into things.Justin
Yes it is.Originally posted by gonzo View PostIs it possible to turn a garage that has 2 doors into just 1 door? Theres 2 doors and seemingly a decorative divider in between the doors.
If your have a standard 1 door garage it should be a 8x7 with a 1 foot support between the two and then another 8x7 door.
To properly convert it to one door, you'll have to order a 17x7 door (Specialty door).
You'll need to rip the sheet rock above the doors away and reinforce the header. (not hard to do, but you don't want a 17 foot unsupportive span.). Usually you'll have to put in a 20 foot steel angle in.
Whatever the angle costs, removal of the wall, drywall, etc.. Pluse the 17x7 door, and then re-drywall, etc...Originally posted by snacksnack View Postapproximate cost to do this?
I can get doors at wholesale, but I generally don't like installing full doors. (I did a ton of peoples houses on Dfwstangs). These days I prefer just to fix people's doors.
My guess, to remove the post and do all the stuff will probably cost you near $1000.00 to $1500.00 PLUS, PERMITS. And anything the City Inspector will require you to do. (YES YOU MUST HAVE A PERMIT TO DO THIS).
