Looks like I might be picking up a free Morgan 6 person hot tub. It is a charcoal system, are these things worth a damn? I'd prefer to have it converted to salt water if it isn't ridiculously expensive. What is going to be involved in wiring this thing up to my old ass 1966 house? It comes with all the wiring, but I assume I'm going to need some electrical done. I also will probably need it leveled and "installed" properly in the location I want it in my backyard where there is just currently grass next to my covered patio. Advice? Anyone on here do this type of work? Muchas Gracias.
Hot Tub gurus?
My son was conceived in a hot tub in front of another couple, good times. Time machine included?Originally posted by talismanI wonder if there will be a new character that specializes in bjj and passive agressive comebacks?Originally posted by AdamLXIf there was, I wouldn't pick it because it would probably just keep leaving the game and then coming back like nothing happened.Originally posted by BroncojohnnyBecause fuck you, that's whyOriginally posted by 80coupenice dick, Idrivea4bangerOriginally posted by Rick Modena......and idrivea4banger is a real person.Originally posted by JesterMan ive always wanted to smoke a bowl with you. Just seem like a cool cat.
Originally posted by Vertnut View PostDefinitely get some electrical advice. It might require a 220v 50amp dedicated circuit, depending on the motor/pump size.
There we go, the previous owner was mentioning something about this, I just couldn't remember the specifics. How much of a bitch will it be to get that set up?
Prolly the same one!!!Originally posted by idrivea4banger View PostMy son was conceived in a hot tub in front of another couple
None at all for a licensed electrician. I'm sure nanus can suggest a IBEW buddy for you!!Originally posted by talisman View PostThere we go, the previous owner was mentioning something about this, I just couldn't remember the specifics. How much of a bitch will it be to get that set up?
God bless.It is easier to build strong children than to repair broken men -Frederick Douglass
my electrician usually charges me $50-100 plus materials for side work
materials are going to suck if it's a long run of 220!
Originally posted by Cooter View Postmy electrician usually charges me $50-100 plus materials for side work
It going to end up being right next to my utility room with washer dryer, so it shouldn't be too bad. Plus the guy said he was going to give me all the wiring, and he has it way off in his sideyard, so I should be in good shape. He turned his house into a rent house and just wants to get rid of it. This is going to be awesome.
Should be a few hundred bucks. They will have to wire it from your breaker box to wherever you want it. Plus it its out in the yard put it in a pipe etc etc... One reason I bought this house I have 220 in the garage and back porch even though I don't use it.Originally posted by talisman View PostAllow me to better ask that question, how much is it probably going to cost me? I'm sure as hell not touching it. Me and wiring don't mix.
Solid reasoning.Originally posted by Couver View PostShould be a few hundred bucks. They will have to wire it from your breaker box to wherever you want it. Plus it its out in the yard put it in a pipe etc etc... One reason I bought this house I have 220 in the garage and back porch even though I don't use it.
