I got a couple of those HTC Vives so me and the wife and friends can play co-op VR. Already have all the necessary hardware to do that. But what I need is a wall that I can take down if necessary. I might want to use the room for something else for a while. Then later on, be able to put the wall back up and play VR again. And I just really don't want a permanent wall or room divider in there.
So I need to come up with a way to make an easily deconstructable wall. Only thing I've come up with so far is pvc. 4 sections of PVC held together by some kind of connector. A dull black fabric would span the gaps between the PVC. Then when I wanted to take it down, I could disconnect the 4 sections of this makeshit wall, and stuff them under the bed or something.
Good idea, or bad? How would you go about doing this? Maybe pvc is a crappy idea and I should be using something else.
