Used dirt bike parts? Looking for a stock rear spring
  • Used dirt bike parts? Looking for a stock rear spring
    Anyone know of a place that would be good to call to try to find a stock CR 250 rear spring.
    Mine is a 2003. I believe they are the same from 02-04
    Thanks in advance.
    2004 GMC Sierra, tuned by Sam
    Originally posted by Stephen
    FUCK!! im gay then
    Shop MotoSport.com for all of the best deals, service and selection in aftermarket and OEM dirt bike and motorcycle parts, riding gear, tires, accessories and casual.
    Or a donor bike.
      call mr. motorcycle in fort worth. they are a used part recycler
        Ebay.
        If you're ok with spending $80 you can get a stock rate spring from Race Tech
          Thanks for the responses, I was more looking for a used one/take off. I want to see if I like it before I buy from racetech.
          I bought this bike as a used and abused race bike and it has way too much spring on the back of it, I have gotten it back it tip top shape, but damn it's harsh.
          From what I understand, the stock spring is set up for my weight. So a used one should be just what I need.
          FUCK!! im gay then
            Damn, struck out.
            I know there is someone somewhere with one in their garage or a shop that has some in the corner. But I don't know where to start.
            Know of a local dirt bike forum that I could check the classifieds?
            FUCK!! im gay then
              do you know the measurements on your spring? length, inner diameter?
              i would assume you could use other 250 springs of the like.
                besides ebay, only other thing i cant think of is calling jim cabora at raceworx, and see if he has anything lying around the shop.
                  do you know the measurements on your spring? length, inner diameter?\
                  a. No man, I don't.
                  b. I was thinking the same thing, I did find one from a 98. Haven't yet found a place that shows applicable year ranges by product, but I haven't been able to spend much time looking either, i'm at work.
                  Cool, if it comes down to it I will do that. Thanks again.
                  FUCK!! im gay then
                    or you could be a total bad ass and ride that thing all the way to my house!
                    "PSH!!!"
                      Have you set the sag? if the sag is not set correctly it will make the spring seem stiff. Once that is set then you can adjust the rebound and compression to help smooth out the ride. Where is the compression set at?
                        and do a wheelie on your face!!
                        Sag is set, compression and rebound surely do need some work. It has an aftermarket rear spring that I don't know anything about except for it is much stiffer than stock, my riding buddy has the same bike with a stock spring and I would like to start off with that spring. If I recall correctly the compression and rebound are centered.
                        FUCK!! im gay then
                          If you have the race sag set, and the static sag is under spec, then you need a stiffer spring, if static sag is over spec then you need a softer spring.
                          Go here and click on "calculate spring rates and display available springs" under the rear shock section and it will ask your weight and what type of riding to give you the correct rate:
                            http://racetech.com/ProductSearch/1/Honda/CR250R/2003
                            Awesome, thanks!
                            FUCK!! im gay then
