Originally posted by tribaltalon
Speed Comparison: GT vs. F1
because they aren't comfortable with momentum, they are point and park drivers........ On an oval the most disturbing part is how long you are actually not using either pedal (coasting). Most R/R's overdrive and overstop the crap out of an oval car.pinto gt with wood trim
Theoretically yes you could drive on the ceiling. The only problem is that they would have to design an engine that would work upside down.Originally posted by twicepipes View PostI've heard that F1's produce so much down force that at 150mph they would be able to drive upside down and stay that way.
Any fact behind this?
A lot of acrobatic/stunt planes still use piston engines (better throttle response, etc) these are modified to fly upside down for extended periods by having additional gas/oil tanks and modified sump system to supply fluids while the engine is upside down.
F1 cars already have a dry sump systems using external reservoirs. Water, oil, fuel would all need modifications so they don't drain out and don't lose pressure. I think the biggest problem would be that oil would eventually pool in the cylinders - limiting the amount of timing you want to spend upside down, and possibly requiring your oiling system to need a new sump pickup at the top of the crankcase.
A pressurized dry-sump lubricated engines would work fine, particularly if they use any sort of direct injection where the fuel is vaporized as opposed to be sprayed - you'd have to use a pressurized fuel cell as well.
OR.... Radial engine. that would be a VERY interesting looking F1 car. LOL!Originally posted by scootro View PostTheoretically yes you could drive on the ceiling. The only problem is that they would have to design an engine that would work upside down.
A pressurized dry-sump lubricated engines would work fine, particularly if they use any sort of direct injection where the fuel is vaporized as opposed to be sprayed - you'd have to use a pressurized fuel cell as well.Originally posted by Taya Kyle, American GunThere comes a time when honest debate, serious diplomatic efforts, and logical arguments have been exhausted and only men and women willing to take up arms against evil will suffice to save the freedom of a nation or continent.
Holy shitOriginally posted by davbrucasI want to like Slow99 since people I know say he's a good guy, but just about everything he posts is condescending and passive aggressive.
I completely agree. Im sure it won't sound bad but an NA v8 at 18k rpm is about the best sound you could ever ask forOriginally posted by TENGRAM View Postcouple thousand less RPM than this year and it's a six cylinder. I don't think it's gonna sound nearly as good.www.hppmotorsports.com
ᶘ ᵒᴥᵒᶅ
