needs more guns, and it needs a cattle guard.
Zombie apocalypses vehicle (model inside)
Just like the Baja 1000 you run an external catheter down the leg and onto the floorboard. Problem solved.Originally posted by cobrajet69 View PostAnd not even this ^ will help.
The zombies will climb under you cab, hang on until you stop, and jump out on you and eat your face when you get out to pee!
David
Needs bottom mounted guns, expanded metal holes in the floorboard. Guns are the answer to everything.Originally posted by cobrajet69 View PostAnd not even this ^ will help.
David"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Might be a good idea to construct an entire vehicle out of nothing but guns.Originally posted by 5.0_CJ View PostNeeds bottom mounted guns, expanded metal holes in the floorboard. Guns are the answer to everything."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Ya need to plate the underside. Everything scratch built is made of evergreen sheet styrene(spelling?) Basicly sheets of plastic. Guns are on there way, should have them by the weekend. I'm loving al the feedback on this. I knew I would get some good input from dfwzombiehunters.net lol
If a zombie can only die by destroying the brain, why would a mild shock on a rotting corpse be useful? The same goes for barb wire. Why would a 1/4 inch metal spike stop the unliving when they dont feel pain?Originally posted by Johnny Armijo View Postyou should put barbwire around the bottom with a couple batteries hooked up to it to shock them
If it were me, I'd weld on steel tubes 10" or so from the chassis all down the sides so you can brush up against walls or buildings and knock them off.
but then again if it were me I'd be in an armored Komatsu D5 with an arsenal inside."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
