This is how you charge your car battery with a chainsaw.
I've had a battery die while out camping before. Sadly I didn't have a chainsaw. Gratefully, I had a manual trans and roll started that bitch.Originally posted by line-em-up View PostI'll keep this in mind if I ever happen to be out in the middle of nowhere with a chainsaw and a spare fan belt and I leave my lights on and run my battery down. Because that has happened to me before...never.
i bet if we lived in Alaska this could be valuable knowledge though!Originally posted by line-em-up View PostI'll keep this in mind if I ever happen to be out in the middle of nowhere with a chainsaw and a spare fan belt and I leave my lights on and run my battery down. Because that has happened to me before...never.
Pretty sure this is useless, alternator needs signal to "excite" the rectifier. Now maybe if you turn the key to "on" prior to doing this you have a chance of making this work.
Also 99% sure the alternator does not care if it spins backwards.
Why?Originally posted by jakesford View PostUnless you have a completely dead battery and an EFI vehicle... then you are still fucked
Why?Originally posted by 91CoupeMike View PostSo much for ECM voltage regulators lol
?Originally posted by John Galt View PostPretty sure this is useless, alternator needs signal to "excite" the rectifier. Now maybe if you turn the key to "on" prior to doing this you have a chance of making this work.
Also 99% sure the alternator does not care if it spins backwards.2015 F250 Platinum
The battery won't charge unless the regulator allows it to. If the batteries are completely dead, there's no way for the regulator to allow the alternator to begin charging.
Most modern vehicles won't allow it without a corresponding crank signal
EgggzachlyOriginally posted by Cooter View PostThe battery won't charge unless the regulator allows it to. If the batteries are completely dead, there's no way for the regulator to allow the alternator to begin charging.
