Help Me Pick A Wheelbase For My International Harvester
I'm not opposed to the 130" WB with the 8ft bed but that would require stretching the frame, new driveshaft, fuel lines, brake lines and E-brake cables.
I need to redo this with a better profile shots but it looks like I am leaning towards the 118" with a 7ft bed. That seems to balance out the length of the front end. Plus, the bed is still usable.
Now I just need to find a deal on an extended cab S10.
From what I have read, the Blazer sits higher and like you said, the longest wheel base in 107.5.Originally posted by bubbaearl View Postthe s10 blazer frame is 107.5 and will let you keep the bed intact. the s10 pu frame has the kick up .
Yeah, I always do tons of research before I try anything like this. Then again, this isn't my first frame swap.Originally posted by bubbaearl View Postbefore you get too carried away set the cab and front on a frame. aframe front ends dont really work too well on early iron. fender clearance and rad mounting can be a nightmare .
