Originally posted by 5.0_CJ
The $4000 Jeep TJ project
If you don't wanna lift it high, at least do a CV/SYE so you can get rid of the t-case drop. Kills ground clearance, especially with that factory shovel skidOriginally posted by 5.0_CJ View PostFixed, got the death wobble fixed, new BFG KM2's - was on the highway at 70mph worked great. Did a transfer case drop and everything is perfect.
That's an expensive little mod.Originally posted by bottlerocket View PostIf you don't wanna lift it high, at least do a CV/SYE so you can get rid of the t-case drop. Kills ground clearance, especially with that factory shovel skidOriginally posted by JesterEvery time you see the fucking guy....show him your fucking dick.. Just whip out your hawg and wiggle it in his direction, put it away, call him a fuckin meatgazer, shoot him the bird and go inside.
Fixed the death wobble. I ended up having 1" of toe on my front, which is ridiculous. I pulled the toe back out and set 1/8" and some new BFG KM2 35/12.50/15's and it drives like a dream.
We've come a long way baby!
It's really nice to be able to drive wherever I want in it, rides GREAT with these tires, the 31's were absolutely ridiculously rough. I ended up having to do a TC drop, but I think with my 1" MML it's a little too much, so I'm going to bring it back up 1/2" or so when I get the time."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Did you get the extra space cut out for the shifter?Originally posted by JesterEvery time you see the fucking guy....show him your fucking dick.. Just whip out your hawg and wiggle it in his direction, put it away, call him a fuckin meatgazer, shoot him the bird and go inside.
I ended up moving the center console back 1.5", but even still 2nd gear needs a push, I think I'm going to heat up the shifter handle with a torch and bend it.Originally posted by motoman View PostDid you get the extra space cut out for the shifter?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
July 4th weekend? River?Originally posted by 03trubluGT View PostWhen are we going 'wheeling?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Yeah you're definitely right there. The TC Drop I did is ridiculous given the MML I already did, I probably only needed 1/4" but got 1.5" with this TC Drop. I'm going to just use washers when I get around to adjusting it again. The reason I chose a 3" SA lift w/ 1.25" BL was to avoid the SYE.Originally posted by bottlerocket View PostIf you don't wanna lift it high, at least do a CV/SYE so you can get rid of the t-case drop. Kills ground clearance, especially with that factory shovel skid"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
You still needed a T-case drop even after the 1.25" BL? Strange, most times its not necessary. Were you getting bad drivetrain vibes without the drop?Originally posted by 5.0_CJ View PostYeah you're definitely right there. The TC Drop I did is ridiculous given the MML I already did, I probably only needed 1/4" but got 1.5" with this TC Drop. I'm going to just use washers when I get around to adjusting it again. The reason I chose a 3" SA lift w/ 1.25" BL was to avoid the SYE.
No not bad at all, just very slightly, I couldn't really feel them, but I did feel a sap in powder do to some slight binding. I really think I only needed another 1/4"Originally posted by bottlerocket View PostYou still needed a T-case drop even after the 1.25" BL? Strange, most times its not necessary. Were you getting bad drivetrain vibes without the drop?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Yea good call not pushing it. Did the drop not have removable washers so you can shorten the drop? Did it come with a new t-case linkage too?Originally posted by 5.0_CJ View PostNo not bad at all, just very slightly, I couldn't really feel them, but I did feel a sap in powder do to some slight binding. I really think I only needed another 1/4"
I did do the t-case linkage drop, but even think I think I need more (having a 1" BL AND a TC drop is almost absurd, my motor is at such an angle it's almost ridiculous, I had to move the console back just to get it into 2nd, 4th, and reverse, because the shifter was hitting the bezel. It had no adjustment, 1.5" or nothing. I was in a rush to get it done. But, I have a box full of a thousand 1/2" washers, so I'll do it this next weekend and bring it to like 1/2" or so and see how it does. I'm concerned about lubrication issues with my motor tilted so far back.Originally posted by bottlerocket View PostYea good call not pushing it. Did the drop not have removable washers so you can shorten the drop? Did it come with a new t-case linkage too?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
I haven't torn into mine to where I would know, but isnt the pickup at the back of the motor anyway? Damn thing takes 6qt of oil, I'd hope lubrication isn't a problemOriginally posted by 5.0_CJ View PostI did do the t-case linkage drop, but even think I think I need more (having a 1" BL AND a TC drop is almost absurd, my motor is at such an angle it's almost ridiculous, I had to move the console back just to get it into 2nd, 4th, and reverse, because the shifter was hitting the bezel. It had no adjustment, 1.5" or nothing. I was in a rush to get it done. But, I have a box full of a thousand 1/2" washers, so I'll do it this next weekend and bring it to like 1/2" or so and see how it does. I'm concerned about lubrication issues with my motor tilted so far back.
I've seen some pretty crazy setups. Unfortunately the SYE/CV is the most straight forward way to go, but also the priciest. On a budget, its tough to get more than 3" of lift out of the TJ w/o doing it unfortunately.
