Pull the gpu, boot off the on board video and see if you get display.
No display after build
Start from scratch, pull it all off, cooler included, reseat the cpu, test post. If it beeps, count the beeps and reference the manual, then try again with a single dimm, rinse, repeat.
Then too, the mobo could be bad. If this is your first build and you're not careful about ESD, you could have inadvertently damaged the mobo with static during handling.
I wish you were closer, I'm off from FedEx this week and could look at it, but I can't make the haul to Midlothian.
gigabyte is shit. Every one of their mobos has shit the bed on me."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by CJ View Postgigabyte is shit. Every one of their mobos has shit the bed on me.
Originally posted by Tx Redneck View PostI've had great luck with them and this instance wasn't a bad mobo. Rather, the mobo was made before the generation of cpu he purchased and needed a bios update to support it. I didn't have a 6th gen Intel, so he'd would have had to send it to Gigabyte to have it flashed, asked around and hope someone had one they could flash it with, or ask the PoS if they had one they could use and flash it. In the end, it was more expedient and better choice to just get a different mobo and return the original(second for the build actually)."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by CJ View PostI've had three in total, first one they forgot solder joints on the onboard audio, causing an intermittent short. The second one had a PCI-E slot that was misaligned so my GPU's interfered with each other, burning one of them out. The last Gigabyte I had would randomly flash the CMOS when you plugged a USB device in.
Originally posted by Ratt View PostHahaha, WTF!?"When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Originally posted by CJ View PostYes, it sucked. That was my replacement board, too.
I will be honest, since an intel board about 14 years ago, I have never had a mobo work 100% correctly. They stuff so much shit on these boards they never make sure everything works right. I have an Asus board now, and it won't throttle fans. Also, the onboard audio will not work unless the system is powered off completely. If you reset it, the audio doesn't work. Every board is like this in some way, dumbass problems."When the people find that they can vote themselves money, that will herald the end of the republic." -Benjamin Franklin
Copyright © 2024 MH Sub I, LLC dba vBulletin. All rights reserved.
