I'm looking at getting a set of Tokico HP (blue) or Koni STR.T Street struts/shocks for my '93 GT. I'd appreciate opinions on each.... Cost for both is equal.....
Fox body shock preference
Exactly. They aren't Bilsteins or Koni yellows but they are the best of the lower level shocks by far.Originally posted by 92redragtop View PostI had the Tokico HPs on my 92 vert for 3 years with Pro-Kit springs and they were pretty good as a slight upgrade to stock struts/shocks (I eventually swapped everything out for the Maximum Road & Track combo).
I have the qa1's all the way around. They are pretty good shocks. A little pricey though.04 2.6 KB'd Cobra!
Originally posted by Sean88gtThere is something about her that just makes my dick completely take over any thought process. If Russell Brand were on top of her, I'd fuck him just to say I pushed a dick inside of her.
What springs are you running? In my experience there's nothing wrong with Tokicos if you buy the right dampers for the application. Blues are for stock or near stock spring rates. If you try to run blues with stiff springs then yes they will wear out in a hurry. I've run blues and Illuminas on a bunch of different cars and only had trouble when I ran stiff coilovers with the Illuminas.
Bilsteins ride the best of the ones I have run and are great if you don't need adjustability.
For more aggressive or race oriented applications where adjutability is required Konis are great.Atlantic Blue '00 - '03 Cobra motor and TKO600, solid axle, full MM suspension
