Water pump??
  • Water pump??
    Trying to find out what year water pump that will fit my 90 5.0 that is a standard rotation, non-serpentine set up.
    Thanks
    Doug
    90 LX Coupe 5.0
    90 7up Vert. 5.0
    60s mustang 302 had aluminum SR water pump i believe. Early crown vics also bolt up i think. Sorry if im wrong lol
    1993 Vibrant Red Cobra #1741.
      Anybody else have a clue?
      Doug
      90 LX Coupe 5.0
      90 7up Vert. 5.0
        He's right, old 60's - 70's stuff, or some early 80's non mustang stuff.
        63 Fairlane
        Originally posted by forbes
        i call 1911 first then 911
          Why do you have that setup on your car? Just curious.
          63 Fairlane
            i don't yet, but was thinking of doing it that way. I have removed smog pump, removed a/c. Relocated alternator to the a/c compressor location. using the older water pump would simplify my idler arm set up.
            [IMG][/IMG]
            Doug
            90 LX Coupe 5.0
            90 7up Vert. 5.0
              Here another angle,
              [IMG][/IMG]
              Doug
              90 LX Coupe 5.0
              90 7up Vert. 5.0
                I had to flip the idler arm/pulley upside down so that it would pull up on the belt. I found out that i could use an idler arm from a 4 cyl. car. But i need to rebuild the front of the engine. There is a water leak at the timing chain cover and the front main seal leaks.
                Doug
                90 LX Coupe 5.0
                90 7up Vert. 5.0
                  I have my race car set up with the alt up in the compressor spot and a SR WP. I have a good parts guy, and he tried about every part number he could find to get an aluminum one, but didnt get one.
                  My belt runs from the crank to WP and alt - power steering and back to the crank.
                    I have my race car set up with the alt up in the compressor spot and a SR WP. I have a good parts guy, and he tried about every part number he could find to get an aluminum one, but didn't get one.
                    hmm, that's cool. The way its set up now works great, Just wanted to simplify it even more. I think later i will just run a 4 cyl. idler pulley and keep a new style water pump, just in case I ever put the a/c back on.
                    Doug
                    90 LX Coupe 5.0
                    90 7up Vert. 5.0
