how do you check for electrical draw
To see of you have one?
Check battery voltage with leads off, hook leads up and check for a variance.
There will always be a draw because of the ECM and radio. But there is a certain amount of miliamp draw that is no bueno. I think anything over 30 or 40 milliamps is bad.
How do you find where it's at?
Simple, pull fuses until the draw goes away.
Locate said fused circuit, find the problem and fix it.
So disconnect the battery and check the voltage of the battery. Then connect the battery and recheck it and see if there is a difference greater than 30 or 40 milliamps? In other words check the battery's voltage hooked up and disconnect and compare the readings?Originally posted by 91CoupeMike View PostTo see of you have one?
Assuming I understood this correctly and this is all done with everything off,
Next, if I find I have a draw, then pull one fuse at a time and go check voltage at the battery with it now hooked up to see if it changed significantly?
i just went through this and mine turned out to be the connector to the alternator that doesn't go to the battery...i assume it goes to the computer2004 Mustang GT: BBK shorty headers, BBK O/R X, Flowmaster catback, JLT cold air, Trickflow 75mm TB and Plenum, UD pulleys, upper and lower CA's, 3.73, SCT XCal 2 ---- SOLD
Voltage will give a very vague readback.Originally posted by TEAMJACOB View PostSo disconnect the battery and check the voltage of the battery. Then connect the battery and recheck it and see if there is a difference greater than 30 or 40 milliamps? In other words check the battery's voltage hooked up and disconnect and compare the readings?
Get a multimeter and bring it down to milliamps.
Amp = current/power
Voltage = pressure or speed.
