I bought a 93 2.3 dual plug motor from a guy here on the board. I saw the motor run before I bought it. I got the ECM, all acc, and the engine harness. I got it all bolted up to the sand rail today and hooked all the harness back up. I have 45psi of fuel at the rail so I know thats good but I have no spark from the two coil packs. I was told I should have power at the two outside wires on both coils but I dont. The starter will kick the motor over but no start. I dont know if this matters but the fuel is a complete stand alone system and not going through the computer.....Any ideas? The only thing I dont have hooked up is the Alt.
2.3 in a sand rail..no spark....need some help
that comment confused me too. maybe the pump isnt controlled by the ecc, I can see this.Originally posted by 46Tbird View PostThe computer is going to try to control fuel and spark. You say the fuel system is not going through the computer? How would that work?Ring and pinion specialist
I thought the same thing, I just got back inside from making sure I had power on the red going into the PCM. It shows 12 volts. Is the red the only one that should have power going to it? I also made sure it had a solid ground. Do I need to connect the other two plugs that are usually in the kick panel to anything? I have 12 volts on the red wire on the green plug as well.
I have the factory 93 banger harness, I do not hear the ccrm click at all. I will double check the ground going to it being its not bolted to anything right now. It's just sitting on top of the motor. I'm not real sure what the KAM wire is.Last edited by wolferine3; 02-16-2012, 08:06 PM.
