At least its weight that would help with transfer and hooking
Boiling Fuel
I'd take a good look and see if there are areas of the fuel line that should be insulated or wrapped up by the hotside. Get a blanket on the turbo and wrap as much of your hotside as you can. I wouldn't change the tank, but maybe the controller combined with what I mentioned will cure it. Don't they make some kind of fuel cooler as well?
they do make coolers, but i don't know how effective they are and i don't know that i want to add a restriction/added complexity/added risk of a leak to the system.Originally posted by Doug Hatton View PostI'd take a good look and see if there are areas of the fuel line that should be insulated or wrapped up by the hotside. Get a blanket on the turbo and wrap as much of your hotside as you can. I wouldn't change the tank, but maybe the controller combined with what I mentioned will cure it. Don't they make some kind of fuel cooler as well?
the fuel line doesn't come close to the hot side at all, but at it's closest point (still a good 8" from the manifold) it is all wrapped.
as for the blanket i think that is going to be my next purchase. if nothing else it'll help keep at least some heat out of the engine bay.
i think rerouting one of the fuel lines from under the front of the intake (sandwiched between the intake mani and the water pump) will help
here is a picture, i outlined the fuel lines in blue. notice the line that goes to the front of the driver side rail goes under the intake manifold. i am going to reroute it to go above the manifold
