Which oil sending unit
  • Which oil sending unit
    Are they the same for 302 and 351. I dont want to ask the parts store guy cause he wont know. My car is a 91 fox with a 351 swap.
    Thanks
    They are the same
    '93 Cobra-Coyote Powered
    '13 Dodge Cummins
    '14 Rubicon X
      Since the gauge in the dash an be inaccurate, is there a way to put a gauge by the sending unit also and keep the factory gauge working?
        tee and use 2 senders
          This, or just use a mechanical oil pressure gauge.
          '13 Dodge Cummins
          '14 Rubicon X
            I was wanting to do both. T it, and the one under the hood be mechanical.
              Inclined folks can remove the hex fitting from the block, drill and tap to 1/8"npt for another feed. I would use both the factory in the dash and a mechanical/electric aftermarket gauge.
                Where can I get fittings like this?
                  Locally
                    oreillys or hardware store
