A1000 Controller or not?
  • A1000 Controller or not?
    About to install sump tank in my Fox
    with the Aeromotive A1000 pump
    Car is mainly a toy limited street use with track times.
    Need some feedback from folks here running the similar pump with or w/o
    Fuel Pump Controller. tia
    Also planning on installing pump bolting to the hard shell tank cover
    good, bad?
    Mock up- will have 2 filters 100 micron inlet>10micron outlet
    no controller. tank covers are fine.
      I ran the controller. Doesn't hurt anything. I also had the pump on the shell. Worked fine!
      00 GT
      Twin Turbo Street Car
        I would use the controller if you are planning on doing any street driving at all. My A1000 (without controller) would heat the fuel up so badly that it would eventually vapor lock in the feed line and leave me stranded on the side of the road.
        - Darrell
        1993 LX - Reef Blue R331ci
        1993 Cobra #199 - SOLD
          been there done that
            I battle with this every summer here in TX. so I would run one if you have it.
            --carlos
              Thanks for the help
              if I do decide to use a controller,
              Does it have to be Aeromotive?
                Originally posted by robert View Post
                Thanks for the help
                controller, Does it have to be
                Aeromotive?
                this one is supposedly real nice and a LOT cheaper then the aeromotive one:
                Delta Current Control, lincoln, Mark VIII, radiator, cooling, variable,speed,E911, Brian Baskin, relay, flexalite, Flex-a-lite,spal,automotive,accessories,cooling,electric,fan,fuel pump,radiator,transmission cooler,fal,monster electric,accessories,focus,honda civic,acura integra,toyota tacoma,wrangler,ranger,bronco,mustang,scirocco,electra,ford,f-150,truck,2sp,FK35,FK60,FK50p,FK85p,50p35
                  I ran mine without a controller, had it hanging outside the shell, never had any vapor lock issues.
                    http://www.dccontrol.com/flcontrol.htm
                    That's interesting from Fan controllers now pump controller,
                    Thanks will check it out.
                      I would use controller the Texas heat is going to be your enemy with that pump.
                      http://DallasGunTrader.com
                        I have mine set up just like yours and once the temps hit the 90* combined with a 30 mile commute its on.
                        --carlos
                          If mounting to plastic cover, use large fender washers on back side. This will spread load across more of the plastic.
                            FWIW, Glenns Performance has an in-line fuel cooler. I'm thinking about using one in conjunction with a controller once I start the build of my coupe.
                            sent from an htc EVO, the iCrap killer.
                            --carlos
                              Is this on an EFI car?
