I remember turbostang saying something about this, and from what I remember he said that since the AN flare fittings and AN o-ring fittings have the same thread pitch you can simply take a flare fitting and put a AN o-ring on it and use it like it was always an o-ring fitting. If whatever the fitting is going into (such as a pump or a regulator cannot take the flare portion of the fitting you can grind the flare off and effectively have a AN o-ring fitting without the additional cost. I pm'd Brooks about it but I haven't heard back, going to put another large order into Summit and can save quite a bit of money just buying the normal AN fittings and converting them rather then buying the more expensive AN flare to O-ring fittings.
Also, anyone got a Summit Discount Code?
