Originally posted by Cobraman
Help! 2000 durango
Just put 4.56s in it.Originally posted by Cobraman View PostThat would be awesome. When in drive it struggles to get going, but once you are up to speed it is fine. It feels like it is trying to start in 3rd. When you put it in "1" it takes off just fine, but it doesn't feel like first, it feels like second because it turns okay rpm at 40.
Yea, and the 2nd syncro gear will go out 100 miles later. Then he will throw your money back at you and tell you to never bring that car back.Originally posted by 91CoupeMike View PostKenny Wilson, he can rebuild that transmission for you.
He operates a great shop, but that little fit he threw was unprofessional IMO. I would (and have) use him again.Originally posted by BuzzoSome dudes jump out of airplanes, I fuck hookers without condoms.
Get a vin and a carfax.Originally posted by Cobraman View Posthalf the miles, one year warranty...?
I do this for a living, I don't want to see you blow money. Every single one needs what your does. Put the parts in it, or put the parts in the other one."If I asked people what they wanted, they would have said faster horses." - Henry Ford
Experience is what you get when you don't get what you wanted....Originally posted by Baron View PostGet a vin and a carfax.
Remember cobraman, this guy sells used parts for a living
yeah. Shifting issue isn't all. I has a pretty bad slip as well. Hell, maybe I'll just look for quotes to rebuild it. I'll break it open this weekend and see what I can see.Originally posted by Baron View PostGet a vin and a carfax.
Already did a vin and carfax2012 GT500
Don't take off the valve body unless you have a trans rebuild book, they have a order the bolts come loose so it doesn't fall apart.
Snap rings and springs after that!
(Dunno if the parts you need are easily changed)
on the replacement trans?Originally posted by Cobraman View Postyeah. Shifting issue isn't all. I has a pretty bad slip as well. Hell, maybe I'll just look for quotes to rebuild it. I'll break it open this weekend and see what I can see.
Already did a vin and carfax"If I asked people what they wanted, they would have said faster horses." - Henry Ford
Is that the same bad synchro that was aka bad throw out bearing?Originally posted by crapstang View PostYea, and the 2nd syncro gear will go out 100 miles later. Then he will throw your money back at you and tell you to never bring that car back.
No, that was the throw out bearing on Jack's car. It literally blew up 20 miles after installation. I told him to wait and put in a FOMOCO piece, not a broreally? partOriginally posted by 91CoupeMike View PostIs that the same bad synchro that was aka bad throw out bearing?Originally posted by BuzzoSome dudes jump out of airplanes, I fuck hookers without condoms.
