I recently got an 88 fox that is a turbo 302 it has a methanol setup that just needs hooked up I wanted to add a small shot to help when launching I've read that you can use both but just wanted to get actual user feedback so any info is greatly appreciated guys
Anyone using methanol and nitrous
Why couldn't you? Methanol has a roughly 2:1 consumption rate, or half as much BTU's as gasoline does, the advantage being resistance to detonation and it cools the intake charge. Be careful though, if you lean one out it's gonna fuck up a buncha stuff!
having enough flow for alcohol with nos is a real problem, alcohol is CH4O.
It contains oxygen inside it already, addng N2O, adds more o2. There gets to a point where stuff gets too hot and starts to melt. if the car is already on alky fuel, use racegas for the nos setup. just what I think.
I reread your op, are you just trying to cool the turboed air charge with the alky while using nos off the line on racegas?Don't worry about what you can't change.
Be honest, even if it hurts.
make sure it's rich enough and
throw a hobbs switch in there somewhere on the fuel line to the nos.Originally posted by Smashmix View PostYeah I think I'm gonna just plumb it in at the throttle body I've heard a lot of good things about using itDon't worry about what you can't change.
