How do you choose what valve springs go good with a specific cam. I'm installing a tf stage one cam on gt40s with 1.6 rr's
valve spring question
I am dealing with the same issue, for a drop in replacement, you don't have a whole lot of options. I'd go with the Crane 44308-1 kit. If you want to machine the head, set it up for ls1 valve springs and get some PSI LS1511ML springs for it.Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
Then i'd go with that crane kid for mild applications, ed curtis has a nice PAC spring kit if you wanna get a bit wild.Originally posted by elongoria View PostNo ls swap
160# at 1.800”
420# at 1.150"
.625” Lift Capable
If you want to cut your valve seats, I have some brand new Comp Cams double springs that I'd be willing to let go. I'm not going to use them. They were bought to use with a Wolverine 1087 cam which is pretty similar to the TFS 1 cam.
Other wise, I think the only spring kit still available that'll fit with no machine work is the TFS spring upgrade kit.
Alex's GT40 drop in springs.
http://www.alexsparts.com/sb-ford-gt...it-hyd-roller/
Ford Racing GT40 springs...
http://www.americanmuscle.com/frpp-v...s-gtheads.html1991 5.0 Mustang LX-Hatch, BBK Cold Air Intake, BBK Headers, BBK X-Pipe, Flowmaster 40's, HPM C/C Plates, Cobra Sway-Bar, UPR Subframe Connectors, UPR Control Arms, FRPP Aluminum Driveshaft, FRPP "C" Springs, FRPP 31 Spine Diff, Moser 31 Spline Axles, FRPP 3:73 Gears, Tokico Blue Shocks, King Cobra Clutch, MSD Ignition, Taurus Electric Fan, BBK Gripp Shifter, & More
Here's what I'm using with GT40 heads, Crane/Cobra 1.7 rockers and Crane 2031 cam on my '92 LX:
Don't use the teflon valve seals that come with the kit though. Just get Fel-Pro valve seals from O'Reillys.
Marcus'99 Jeep Wrangler Sport 4.0L
[QUOTE=Exile;1090960]Alex's GT40 drop in springs.
I second this . I have used them on multiple builds with great results . Easy and complete kits .Big Rooster Racing
Just got off the phone with Alex, great guy to deal with!Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
so what'd ya go with?Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
