I have hd some wiring issues with my electric fan today. First the constant 12v for the relay broke. Got that wired back up and then the ground came loose for the relay on the way home. Those are the only two wires I touched.
Dual efan with relay and 195 thermostat controller. 12v ignition comes from the wiper motor harness.
The problem now is, when it is wired up, the efan runs all of the time, including when the key is off. If i remove the ground wire the fan stops, however, the wiper circuit stays hot when the key is off. I pulled the relay thinking a pole inside was stuck, no luck, still had the same issue, could it be the thermostat?
