Originally posted by racrguy
Engine Rebuild - 302
Start with a leak down/compression test to ensure the bottom end is healthy. No sense in throwing money into the top end if the bottom end is no good. I have a leak down tester and a compression tester if you need them. Both easy, free tests to do. Then we can give you some ideas on a nice top end that would fit your budget. A lot of these guys love giving suggestions on the best parts, or LS swaps, but forget about someone else's budget.Scott Ganow
Lone Star Performance
16300 Midway Rd
Addison, TX 75001
214-630-5006
I'll agree with the others, figure out if your short block is useable, then re-use/rebuild/replace and go with a heathly HCI setup. Screw spending $2,000 or more for a block that you most likely won't push hard enough to justify spending that much on.
Originally posted by 00KBGT View PostStart with a leak down/compression test to ensure the bottom end is healthy. No sense in throwing money into the top end if the bottom end is no good. I have a leak down tester and a compression tester if you need them. Both easy, free tests to do. Then we can give you some ideas on a nice top end that would fit your budget. A lot of these guys love giving suggestions on the best parts, or LS swaps, but forget about someone else's budget.
<---- IN North Garland
Originally posted by cool cat View PostI'll agree with the others, figure out if your short block is useable, then re-use/rebuild/replace and go with a heathly HCI setup. Screw spending $2,000 or more for a block that you most likely won't push hard enough to justify spending that much on.
Originally posted by racrguy View PostDid you miss the SC and 500 RWHP part? Either one of those is enough for me to warrant a dart block, both together make it a requirement. IMO
He said 500 HP, no where was RWHP mentioned. He also said "drive it from time to time... don't want it to be slow", and that building a 500 hp motor would more than likely be more than he wants to spend. Thus the reason why I suggested a healthy HCI combo. If that isn't enough power, then it is time to pony up for the dart block.
Very good point. well taken.
May do the leak/ compression test and go from there..
Thoughts are H/C/I for now.
Having just built a new dart 347 I would have gone this route or something similar if I could do it all over. I have over 6k in mine and reused the rods and crank. Even if I needed to have it torn down and inspected for piece of mind I would have come out a lot better.
Last edited by 93coupett; 09-17-2013, 07:42 PM.www.cowlgaugeconcepts.com and on Facebook
