1994 gt help
  • 1994 gt help
    just bought a 1994 gt off of ebay was told it runs perfect no issues......well guess what?
    around 3500 rpms it starts bucking and pinging and wont go...
    did a full tune up cap rotor wires spark plugs checked fuel pressure changed the injectors....
    and it still does it...
    113,000 miles 5 speed yellow in color.
    any help would be great..
    where should I look next.
    oh timing is set at 10
    thanks
    Pip or distributor
    07 GT500
    05 SRT10
    88 turbocoupe T-bird
    93 Cobra
    86 coupe
    Ducati 848
      Also look at the Maf Sensor, see if the little diode looking pieces have any heavy build up or fuzz on them. If so clean it with Mass airflow sensor cleaner, it's made by CRC and should be available at any parts store.
        that's sounds like a cheap fix...ill do that tomorrow...
          I've got a complete reman dist with less then 200 miles on it for a 94-95 if ya go that route.
            Distributor buy a msd
              where are u located snackshack?
                does any body have a dizzy I could use to check to see if its the dizzy
                im in royse city but work in rockwall
                how about u whiteboy?
                  Does fuel pressure hold strong if you mash it above 3500? Have a buddy with a 95 that had the exact same problem ended up being the fuel pump.
                    Fuel Filter? Verify TPS voltage throughout entire sweep.
                      I'll check the fuel pressure while driving. I just checked it idling and revving it up
                        make sure the spout jumper is in place
                          drove it with the fuel pressure gauge and its fine....I played with the distributor and found the base for the cap was loose so I tightened it but didn't change anything...so I looked inside it and put it back together and it ran worse...so im thinking the distributor is shit...
                            tps voltage was .95 and 5.25 wide open
                              Lol at yellow 94 mustangs
                              Mine doesn't run either. ..
