Front and rear end suspension swap?
  • Front and rear end suspension swap?
    Looking to change out the front end on a 65 mustang on a budget ..and looking to put a 8.8 in the rear looking at a 98 mustang gt ,would any of that fit ...any info would help thanks
    not really.
      That rear end is too wide, you would need to narrow it. Then you would probably want 5 lug axles too.............
      63 Fairlane
      Originally posted by forbes
      i call 1911 first then 911
        Someone should make a thread on this....
          At the HOT ROD How-To section, you’ll learn how to make improvements to your own special hot rod, drawing from the DIY knowledge of the HOT ROD team to learn more about how-to make more power from your engine, improve your suspension, make your brakes stop better, and much more. HOT ROD will also let you know about the latest products and trends in the DIY muscle car building arena.
          If you want leaf springs look for an explorer/ranger, search a little its all out there.
