I rarely have car troubles but I ran into a but yesterday... I'll start by saying it's an 86 Ttop 5.0 with a 90 engine (mass air, bolt ons, etc) battery is in the back and a 130 amp sn95 alternator conversion (one wire). I was driving the car yesterday and I stalled it in traffic and couldn't get it restarted. Seemed like it didn't have enough juice to turn over. Had someone come jump me and everything seemed fine. Got the car to my aunts and turned it off. Tried to start it an hour later and wouldn't crank... Lights and everything come on etc. Jumped it again and it seemed to take a little longer for the car to receive enough charge for it to turn on. Let it run for about 5 minutes turned it off and sure enough tried to crank it and nothing. Seems like it doesn't have enough power to turn the starter. Fast forward to this morning. Took both the alternator and battery to be tested at oreilly and they both passed. Somewhat stumped at the moment. If anyone has had a similar problem let me know or any other ideas would be greatly appreciated. Thanks in advance
Starting problems...need some advice
And check your grounds.sigpic18 F150 Supercrew - daily
86 SVO - Sold
'03 F150 Supercrew - Sold
01 TJ - new toy - Sold
65 F100 (460 + C6) - Sold
Update...when I had the battery tested, they charged it also. Took the battery and alternator back to my car, installed it and it fired right up. I got it all the way home and it seemed fine. Check the battery voltage with the car running and it was at 11.93v turned it off and on a few times (luckily it restarted) let it run for a bit longer and the battery voltage was at 11.79 and seemed like the voltage went down .02 volts every minute or so....kinda weird. The only thing I could maybe think of was when it initially died I tried to restart it like 20 times so maybe I hydro locked it and it was too seized to restart with the normal battery volts? Or yes I need to check all my grounds and maybe even scuff them up a bit and reground them.
Ya I have a meter just not an amp clamp...buying one is on my to do listOriginally posted by stephen4785 View PostSounds like the starter is crapping out. Take a volt meter and stick it to your battery. Crank it and see what the voltage goes down to. AN amp clamp on the positive cable to the battery would let us know how many amps its pulling(dont know if you have access to that or not).
Agreed, check the voltage coming off the alt, not at the battery.Originally posted by 0393gt View Postvoltage at battery should be around 12.25 with the car off, and about 14.25 with the car running. That's what mine does anyway..Originally posted by stevoNot a good idea to go Tim 'The Toolman' Taylor on the power phallus.
Stevo
stock pulleys?
by chance will the voltage go up when you rev it upOriginally posted by 86lxttop View PostYa, an update...my car is definitely not charging at idle. Not sure what it is. Had both alt and battery tested and passed. Any way to do it and see for myself? I don't have an amp clamp. I need to buy one obviouslyDon't worry about what you can't change.
Be honest, even if it hurts.
Ya it does.. I little but though. I drove it about 12 miles and the voltage was definitely lower than normal but I let it idle for about 6-8 minutes and the voltage slow crept down until I turned it off, tried to restart it and wouldn't turn over (dead battery)
