I am looking into going to EFI via the FAST EZ-EFI, FAST EZ-EFI 2.0, OR Edelbrock E-street EFI on my 1965 Mustang. I am after ease of use, street ability, easy cold starts, not showing up smelling like a gas tank when I drive it places.
Current setup is:
289 bored 30 over
AFR 185 heads (58 CC)
11.4:1 compression
XR280R Solid Roller Cam (351w firing order)
Holley Street HP 650
Victor JR single plane intake port matched to heads
Hooker Super Comp Headers
Naturally Aspirated
MSD Billet Distributor and 6AL box
Gforce T5 Transmission
4.33 gears
Cam Specs:
Intake: 608 lift, 242 dur at .05
Exh: 614 lift, 248 dur at .05
Best Run to date is 11.82 at 115 mph (never been on a dyno)
1.) Whichever system I go with, I plan to purchase the master kit with inline pump.
2.) The extra ignition timing feature on the Fast 2.0 is a nice addition but not sure if worth the extra money since timing is easy enough to set manually.
3.) I want a clean, minimal wire look when I open the hood.
4.) The only port on my intake for water temp is being used by my water temp gauge, how is everyone handling this? I need a place for the EFI temp sensor and also my gauge sensor.
					Current setup is:
289 bored 30 over
11.4:1 compression
Naturally Aspirated
4.33 gears
Cam Specs:
