Just picked up a very lightly modded 09 gt (longtube headers, xpipes, purple injectors which I assume isn't stock?) And the the gears are apparently aftermarket. The Speedo is way off... I am new to this s197 witchcraft. I was told a tuner is needed. Is that so? Or can this be alleviated otherwise. Thx.
Tuner question
My advise is that getting a tuner really is the best option. It will solve your current speedo issues, once you enter your gear ratio and tire size. However, it is also a data logger and will read DTC codes. It's a good investment. SCT and Bama tuning has good deals on tuners with multiple tunes. And if you request it, will also look at your data logs and make adjustments. Just take the plunge. It's a very capable tool.
Dude, just go on the Diablosport website to see if it is compatible with your car and what options it has.
Edit: Here, I googled it for you.. http://www.diablosport.com/shop/products/trinity.html
It will definitely do what you want it to, and that is a good price, IMO.. New tuners like this one usually run from ~$350 to ~$600 and will do a ton of other stuff too.
I had the Diablosport Predator when I had a mustang which worked well, but it was just a flash tuner. This one is very much like what I have in the Jeep now, where you can run it on the dash with live gauges. I really like mine and don't even use it for the performance stuff..- PRODUCT FEATURES
- All applications supported under one part number. Never worry about getting the right one; If we support, it works
- The Trinity comes preloaded with canned tunes. We spend hundreds of hours developing tunes for your vehicle for maximum safe power and torque for your application.
- Full color touch-screen. Follow the instructions and use the color touch screen to easily program your vehicle.
- Customizable gauge layouts. Save hundreds of dollars on aftermarket gauges.
- Programmable LED lights. Turn the lights into a shift light or a warning light.
- 5 volt input. The input allows you to hook up several aftermarket accessories like wide band O2 sensors.
- Holds up to 5 custom tunes. Use our worldwide network of CMR tuners to step above our canned tunes.
- 93 Octane Performance Tune: 20HP 25TQ
- 91 Octane Performance Tune: 18HP 23TQ
- Premium Fuel Cold Air Intake Tune: 30HP 35TQ
- 87 Octane Performance Tune: 12HP 12TQ
- Touch Screen
- Data Logging
- Check Clear DTCs
- 5 Volt Data Logging Inputs
- Accepts Custom Tunes from CMR
- Calibrate Speedometer for Gear Ratio
- Calibrate Speedo for Tire Size
- Cooling Fan Control
- Disable Traction Control
- Fuel Rich/Lean Adjustment
- Spark Timing Advance/Retard
- Idle RPM
- Top Speed Limiter
- Rev Limiter
- Shift Points
- Torque Management Adjustment
- MAF Curve Adjustment
Just be sure you plug it into your car and make sure it's not already paired before paying for it. These companies may unlock them for a verified original purchaser, but not so much for people buying used.
It's actually an older diablo called the i1000. The sheet still says itll work for my car. I callwd hpp today to see about recalibration. He told me that I don't need to be romping on it until I get a tune. He says I could be running overly lean due to the long tubes, etc.
