My truck currently has a 4:56 gear ratio out back because the previous owner did quite a bit of towing. Seeing as the 300ci already gets shitty mpg's I'm thinking about throwing a higher gear ratio in there. If I were to go to a 3:73, 3:10, or even 2:73 ratio, how many extra mpg's can I expect to pick up? If the tire size matters at all I'm running 31x10.50x15, which is 3 sizes bigger than stock.
92F150 gear ratios?
92F150 gear ratios?
He will spend the rest of the day wondering if he is gay.FORGTN SOLD1ER - xbox gamerOriginally posted by DennyWhat the fuck ever, you fucking fragile faggot.Tags: None
How much will that differ from a 4:56 ratio?Originally posted by thesource View PostDo a 4.10 gear in it.Originally posted by JesterEvery time you see the fucking guy....show him your fucking dick.. Just whip out your hawg and wiggle it in his direction, put it away, call him a fuckin meatgazer, shoot him the bird and go inside.
Originally posted by thesource View Post10% roughly. A 3.90 gear might be a decent gear ratio also. Is the truck a 5 speed or AOD?It's a 5spd. I'll put it this way, when I'm in 5th gear doing 70mph, I'm between 3500-4000 RPM... not quite an overdrive gear.Originally posted by fordracing19 View Post4:10 auto 3:73 5spdOriginally posted by JesterEvery time you see the fucking guy....show him your fucking dick.. Just whip out your hawg and wiggle it in his direction, put it away, call him a fuckin meatgazer, shoot him the bird and go inside.
Yes, stock tire is a 235/75/15 but I'm running a 31x10.50x15 - was running a 265/75/15 which is 3 sizes bigger than stock. I'm worried 3.73 won't be a high enough ratio to really notice a difference.Originally posted by shumpertdavid View PostI'd probably step down to a 3.73 gear, stock tire should be a 235\75r15 I would guess which is about a 29" o.d.Originally posted by JesterEvery time you see the fucking guy....show him your fucking dick.. Just whip out your hawg and wiggle it in his direction, put it away, call him a fuckin meatgazer, shoot him the bird and go inside.
Keep the gears. Put some taller tires on it and it will effectively decrease the gear ratio. If you step down too much in gear with that turd of a motor, you will not like it. Not when you're acclimated to the torque multiplication of the 4.56s. It'll feel like a total turd. Trust me on this.
