Are the 3 clutch dowels in the flywheel ?
I need help.
Fly wheel prob needs balanced. I may be mistaken but I think it needs to be motor balanced too. I aslo think the dampners are diff between auto and stdOriginally posted by Texasmustang View PostHmmmm is there anyway to find out the weight on the flywheel. Cause I purchased the tranny clutch and flywheel all together from a guy.
Is the engine just a stock rebuild to 5.0 HO specs? Or is it just a 5.0(non HO) - I **think** there is a difference in the balance/imbalance depending on whether it is HO or not.
If the engine is a HO from a 86-93(maybe more) it should be a 50oz imbalance on the flywheel and balancer. There may be other identifiers as to which balance you need - hopefully someone with more experience can speak up and help you out..
