E6 heads are on it now. What heads and cam and RR's can I use without fly cutting pistons?
True 86 Flat top Pistons
The size of the relief on the pistons in steve's motor are not even deep enough to make a differance . When we clayed the pistons I made the clay almost 1/4" thick and after a 360 rotation the valves barely touched the clay . I would still clay it but there was a ton of room .Big Rooster Racing
I have a cam degree kit with light test springs . I removed the valve springs , used an old compressed gasket (for a little more safety factor) and watched very closley to make sure not to compress the lifters . But yes , if you were to leave the head assembled you would need a solid lifter to fight the springs .Big Rooster Racing
