I am a decent welder and can get it done,but god it looks like shit. Tons of slag . Is spend hours cleaning it all up from the inside of the pipe as to not damage the turbo
tips for welding tubing mig.
Might be a dumb question to start out, but are your pipes close fitting before welding them up also? That will also minimize anything going thru to the inside to clean up, taking the time to get them fitting right will help a lot.
Might practice more with heat/speed to get it dialed in on whatever tubing you're working on.
*Not a pro, just crap ive picked up*
If I'm going to build it, I'm going to build it.
Also for the rest of the info.
75/25 gas .23 wire.
Welder is a Lincoln 125 it has 4 heat settings, and adjustable wire speed.
I had it on heat setting c with a wire speed of 7-9 when I did this.
I can weld better than this. These are my first two attempts of welding something this thin.
The second weld could have fit better I was just farting around.
Notice all the crap on the inside.
First, I'd bet the heat setting is WAY too high.
Next, you'll have to grind that aluminized coating back at least 1/4". It will weld much better.
Then, most 'weaving' won't work on thin guage tubing, especially with a poor fitting tube. The gap has to be at least what the wire is, or less.
Long story short, I think you'll have to experiment (like what you are doing) and see what works for you. I'll say this though, MIG is much faster and I still TIG weld everything.
I hate welding thin gauge with the mig. Looks like you need lower heat setting. There is probably a chart on the welder that shows you the correct heat settings. It seems like it is never right for how I like to weld, but should get it close then you can adjust your machine from there to get it how you like.
