What do you guys like to use, 36 grit flap disc, 3m bristle wheel (roloc), hard wheel?
Removing mill scale
Removing mill scale
Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.phpTags: None
That sounds quite time consuming, how many passes before it knocks off the scale? I am hearing good things about these norton wheels tooOriginally posted by jw33 View PostI use a wire wheel with a cordless drill on high and acetone.Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
I only worry about the small section that I am welding to get it that clean. The rest of the part might get a blast of brake cleaner and a Scotch brite pad rub down if it is bad enough. All the tubing I've had to mess with wasn't really that bad and still looks fine under a good coat of spray paint.
