I just installed a new cooktop on my island. The cooktop has 4 individual wires (red,black,white,bare), ran through flexible conduit, from the power supply (there is no plug). My island cabinet has a 3-wire junction box (black,white,bare). I connected black to black, red to white, and white/bare to bare. I just want to confirm this is the correct wiring before I turn the breaker back on.
4-wire range to 3-wire 220V junction box
Am I missing something? He went red to white. Unless I'm totally misunderstanding, the range needs 220V but he only has 110V in the wall. The red wire from the range needs a hot lead, but there isn't one there.Originally posted by 8mpg View Postcorrect... red and black are hot leads (110v each) and the white is running the common. Bare is essentially common (ground)
You can use any two wire (actually 3 with bare) to wire in a 220 volt. The black and white will carry loads from each side of the breaker box rails. Most wiring these days carry a neutral (white) and ground (bare). He just needs to check that the breaker supplying the junction box has a 220v breaker and that the black and white wires are attached to the breaker. The proper will be:Originally posted by juiceweezl View PostAm I missing something? He went red to white. Unless I'm totally misunderstanding, the range needs 220V but he only has 110V in the wall. The red wire from the range needs a hot lead, but there isn't one there.
old black to new black
old white to new red
old bare to new white and new bare
The original house wire has both hot leads being black and white. The ground will act as a common and ground so it will go to the bare and white on the new appliance.
Yes, I just skipped right over that the 3 wire box was 220V and was thinking the range was 220 (which it is) hooking to a standard box.Originally posted by 8mpg View PostYou can use any two wire (actually 3 with bare) to wire in a 220 volt. The black and white will carry loads from each side of the breaker box rails. Most wiring these days carry a neutral (white) and ground (bare). He just needs to check that the breaker supplying the junction box has a 220v breaker and that the black and white wires are attached to the breaker. The proper will be:
OP, as said either verify the breaker is a 220V or put a Fluke on it at the junction box to tell.
