I'm looking around for some solid motor mounts.. I see several different types of mounts. What do you guys use in your fox..
Solid motor mounts
I just bought a set of Maximum Motorsports,Originally posted by juic3d View PostI'm looking around for some solid motor mounts.. I see several different types of mounts. What do you guys use in your fox..
still riding in a brown truck somewhere.
I have these on my race car. I don't know if it was poor design of the mount or the weak mount pad on my old Groundpounder k-member, but the passenger side mount got tweaked the first time I took the car to the track! The motor sat cockeyed in the car and I had to put some spacers under the mount to raise the passenger side back up some.Originally posted by robert View PostI just bought a set of Maximum Motorsports,
http://www.maximummotorsports.com/st...roducts_id=930
I just installed a front motor plate to eliminate this issue when I installed a new AJERacing k-member. I kept the mounts and actually put the passenger side in a vice, heated it, and straightened it back out so the motor would sit level. Now the mounts are essentially there to prevent forward/aft movement and to support the rear of the motor since I'm not running a rear motor plate.
I've had the box style Moroso mounts as well and those actually raised the motor up some and were difficult to get into the k-member slot. I think they were a bit crooked.Carl S.
2014 Ruby Red Premium GT A6, stock for now
80 Coupe, Stroked 9.2" Windsor, Yates C3, Dominator, glide, 9.60s n/a, 1.27 sixty 5.48@127.8 nitrous on radials.
9.32@128 pedaling it half track
I had some Holcomb drop mounts in one of my foxes that I liked.
Ded
